Hello
Why Vmix output varies 25, 26 fps. We need 25fps output always.
Regards, Ivan Videv
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
The FPS timer at the bottom of vMix is a guide only. The real frames per second is whatever you set in vMix settings.
FPS timer at the bottom shows exact the same, as FMLE sees as input, so I think it shows real FPS so real output in not stable 25 fps
Regards, Ivan
This is not true, both FMLE and vMix show an average FPS indicator which may be slight above or slightly below 25fps depending on what the system is doing, but the final stream or recording will be exactly 25fps.
