Can Vmix run perfectly on my IMAC? with OS X?
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
wale wrote:Can Vmix run perfectly on my IMAC? with OS X? Short answer: No. Long answer: Yes, with a VM running or BootCamping a Windows versionIf you're wondering if vMix is the way to go for your production without trying it, I would definitely give it my recommendation. Cheers, Håvard Njastad Webshop
Great. I ll like to make it work. A friend told me about how flexible Vmix could be and i'll like to try it on my IMAC.
Joined: 6/10/2014(UTC) Posts: 5 Location: Barranquilla
I'm using a late-2013 imac with one intensity shuttle usb 3.0 almost without problems using bootcamp, it works really well for streaming.
