Joined: 8/16/2019(UTC) Posts: 354  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
Hi all, has anyone tested the Elgato 10GAM9901 Cam Link 4K with vMix, if so what was the results please?
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
well, I thought since you are an experienced forum user you would find the answer by searching here ;)
In any case, the Camlink 4K works just fine. We have used a bunch of them. BUT note that not all sources (some cams, some PCs) are not accepted. Check with Elgato's compatibility list and/or test yourself.
