Simsyuk
#1 Posted : Friday, October 29, 2021 8:28:49 PM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
Hi all, has anyone tested the Elgato 10GAM9901 Cam Link 4K with vMix, if so what was the results please?
richardgatarski
#2 Posted : Friday, October 29, 2021 10:12:32 PM(UTC)
richardgatarski
well, I thought since you are an experienced forum user you would find the answer by searching here ;)
In any case, the Camlink 4K works just fine. We have used a bunch of them. BUT note that not all sources (some cams, some PCs) are not accepted. Check with Elgato's compatibility list and/or test yourself.
