Simsyuk
#1 Posted : Tuesday, October 5, 2021 9:19:54 PM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
Hi all, I've been given some unwanted 4k cctv (comes with decoder unit) cameras and I was wondering if vMix can input each camera as a separate camera, I've had a play using the IP address the system has given me along with the port number but nothing is showing.
Therefore I was wondering if this is possible (currently I'm using a HDMI input).
Thanks in advance.
xaver
#2 Posted : Wednesday, October 6, 2021 3:34:40 AM(UTC)
xaver
normaly you can input the camera as RTSP Stream
therefor you need the complete URL of the RTSP Stream
and this URL is different from cameramodel to cameramodel
rtsp://192.168.1.x:554/user=admin&password=&channel=1&stream=0.sdp?
rtsp://admin:admin@192.168.1.x:554/1/h264major
which camera do you have?
Simsyuk
#3 Posted : Wednesday, October 6, 2021 5:30:14 PM(UTC)
Simsyuk
Thank you for answering and helping. Sadly vMix keeps saying 'No session'. As to the camera it's just a cheap Jennov 5MP POE System 4 channel CCTV with audio (model MC500L_VO).
Not sure if this is any help (I can view on my PC without any issues using it's software), when I click on the camera settings I get this information:
IP: 192.168.0.x
Device Type: IPC
Port: 554
PTZ Port: 8091
Protocol: ACP
vmixLove33
#4 Posted : Monday, October 18, 2021 1:43:24 PM(UTC)
vmixLove33
Rank:: Newbie
As user above said, you need to get the correct RTSP url for your specific camera. your first step should be to get the RTSP video feed working in VLC (vlc win/mac app , Media -> open Network stream). This way you can also turn on debugging in VLC message window and keep trying in order to figure out the correct RTSP URL for your specific cams. (search the web and try various RTSP URLs in VLC)
Also, as that output you pasted above shows "port 554" that should be RTSP support on the ip cam side.
also, important- see if there is anyway to allow/enable a (allow) "Anonymous Viewers" option in the ipcameras web gui/settings. Doing so will atleaste help you to skip the often challenging rtsp auth issues/format.
however there may be other issues on the camera side causing RTSP to not work correctly or to not be following the RTSP spec/standards (in which case, short of there being a firmware update for the cameras, from their manufacture, you may be out of luck). but start with VLC first.
Ive used several video streaming production apps , along with RTSP based video streams (from IP cameras), and vmix is one of the BEST at handling (and playing back) RTSP streams constantly and wo adding delay over time (if you must use RTSP, that is). good luck!
