scaling vertical output over HDMI
Good afternoon, I just installed the trial version of Vmix and I would like to be able to configure the HDMI output to two led televisions that are placed vertically and I can't find a way. Is it possible to scale the output from 16: 9 to 9:16? From already thank you very much
Originally Posted by: goyco2003  Good afternoon, I just installed the trial version of Vmix and I would like to be able to configure the HDMI output to two led televisions that are placed vertically and I can't find a way. Is it possible to scale the output from 16: 9 to 9:16? From already thank you very much That's funny "I just installed the trial version of Vmix" ............. after using it for at least 3 years ? https://forums.vmix.com/...Instagram-in-Vmix-Social
Originally Posted by: doggy  Originally Posted by: goyco2003  Good afternoon, I just installed the trial version of Vmix and I would like to be able to configure the HDMI output to two led televisions that are placed vertically and I can't find a way. Is it possible to scale the output from 16: 9 to 9:16? From already thank you very much That's funny "I just installed the trial version of Vmix" ............. after using it for at least 3 years ? https://forums.vmix.com/...Instagram-in-Vmix-Social Dear Doggy, 3 years ago I installed a version of vmix and used it only during the trial period, with an Instagram problem to fix. After that time I did not use the Vmix again and now I have installed version 24 to test the functions again and see if I can achieve that kind of scaling. I see that it bothers you that trial versions are used, I think you should ask first and if you don't want to help me just tell me. For everything else, the program seems excellent to me.
Originally Posted by: goyco2003  Dear Doggy, 3 years ago I installed a version of vmix and used it only during the trial period, with an Instagram problem to fix. After that time I did not use the Vmix again and now I have installed version 24 to test the functions again and see if I can achieve that kind of scaling. I see that it bothers you that trial versions are used, I think you should ask first and if you don't want to help me just tell me. For everything else, the program seems excellent to me.
Fair enough don't know for HDMI out but for streaming one can https://forums.vmix.com/...rtrait-Presets#post72946also See helpfiles : Streaming quality -> Aspect Ratio / Crop seems here are some ideas also that might work for you https://forums.vmix.com/...62-Mirror-flip-on-output
Thank you very much Doggy for your answer. Greetings
