goyco2003
#1 Posted : Saturday, October 2, 2021 8:24:41 AM(UTC)
goyco2003
Good afternoon, I just installed the trial version of Vmix and I would like to be able to configure the HDMI output to two led televisions that are placed vertically and I can't find a way. Is it possible to scale the output from 16: 9 to 9:16?
From already thank you very much
#2 Posted : Saturday, October 2, 2021 8:53:59 AM(UTC)
That's funny "I just installed the trial version of Vmix" ............. after using it for at least 3 years ? https://forums.vmix.com/...Instagram-in-Vmix-Social
goyco2003
#3 Posted : Saturday, October 2, 2021 1:22:08 PM(UTC)
goyco2003
Dear Doggy, 3 years ago I installed a version of vmix and used it only during the trial period, with an Instagram problem to fix. After that time I did not use the Vmix again and now I have installed version 24 to test the functions again and see if I can achieve that kind of scaling. I see that it bothers you that trial versions are used, I think you should ask first and if you don't want to help me just tell me. For everything else, the program seems excellent to me.
#4 Posted : Saturday, October 2, 2021 4:49:50 PM(UTC)
Fair enough
don't know for HDMI out but for streaming one can
https://forums.vmix.com/...rtrait-Presets#post72946
also See helpfiles : Streaming quality -> Aspect Ratio / Crop
seems here are some ideas also that might work for you https://forums.vmix.com/...62-Mirror-flip-on-output
goyco2003
#5 Posted : Friday, November 5, 2021 12:38:47 PM(UTC)
goyco2003
Thank you very much Doggy for your answer. Greetings
