How to publish XAML with animations
I have a question that I hope somebody can help me with :-)
I'm going to make a production using vMix 4K, where I have made a serie of XAML templates for scoring and statistics with StoryBoard effects in and out. For my presention during the event I receive an internal camera feed where I use the vMix for adding the XAML overlays, my out goes to a number of gigant screens. This works without problem.
My challenge is that I need to provide an extra output signal (fx. external 2) only showing my XAML templates including in and out animations - no camera picture. The receiver of this signal is transmitting a live TV signal for broadcasting and needs access to our overlay(s).
I have tried different configs, but maybe it is not possible using only one vMix!!!
BR Ulrik
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
um@equilive.dk wrote:I have a question that I hope somebody can help me with :-)
BR Ulrik
Would a MultiView input that is sent via a Decklink/Stream function? Eg.: Add all the wished overlays to a Multiview and set external 2 to that input and run it out to a DeckLink/Stream? Only limitation here would be there are no individual control of in- and out animations, they would be duplicated of what you'd run in your production. Cheers, Håvard Njastad Webshop
Thanks Håvard, I will give it a try tonight - hopefully it works!
/Ulrik
Thanks - it worked. The only thing is that all overlays needs to have StoryBoard1/2 for in/out effect!
BR Ulrik
