Feature Requests
Opening multiple list panels at once
Joined: 1/22/2020(UTC) Posts: 47  Location: Montpellier Thanks: 14 times Was thanked: 2 time(s) in 2 post(s)
Hi, I often use many lists, from where I send a lot of videos. Something that would be a game changer for me would be the ability to open as much list panels as I want, instead of having to scroll, select list and then select the desired video to be sent. Do you think it'd be possible ? Does anyone would need it as well ?
Thanks a lot :)
David
Use a controller like Stream Deck?!
Joined: 8/12/2020(UTC) Posts: 18  Location: Bay Area Thanks: 4 times
This would be helpful for me!
Joined: 5/24/2019(UTC) Posts: 8  Location: Pasay Thanks: 1 times Was thanked: 2 time(s) in 1 post(s)
Originally Posted by: mavik  Use a controller like Stream Deck?! I already use a controller, but if you can't monitor what you're doing, it's not that helpful. I need to SEE every lists
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Just my .2 cents
For easy switching between list views and be able to quickly select a item one can use the "ListShowHide" shortcut function (each specifying which list, might have to double hit it) . Works with unpinned frame also.
To have visual overview of all Lists at once i personally would revert to creating some external application that shows every list (with selected marked) in a windows form (list info pulled from the API XML). One could also pull that info into datasources and display in the open data source window ( just click between the various ones instead of having to scroll through a dropdown or have it as one of all combined with the ones selected being marked).
Until this FR is available
Until this FR is available Hey Doggy ! Hope you're well. Thanks for the answer, the shortcut works well indeed, but in a hurry it's not that visual. The API part could be great ! But the same problem would appear with datasources : I'd have to open 1 data source for every video
No you don't , you get a list of all inputs in a List input (either split per list input or all in one big list depending on the xpath used)
Feature Requests
