davidcallahan
#1 Posted : Wednesday, September 15, 2021 2:19:03 AM(UTC)
davidcallahan
I often use many lists, from where I send a lot of videos.
Something that would be a game changer for me would be the ability to open as much list panels as I want, instead of having to scroll, select list and then select the desired video to be sent.
Do you think it'd be possible ? Does anyone would need it as well ?
Thanks a lot :)
David
mavik
#2 Posted : Wednesday, September 15, 2021 2:46:05 AM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
Use a controller like Stream Deck?!
dec33
#3 Posted : Wednesday, September 15, 2021 10:07:45 AM(UTC)
dec33
This would be helpful for me!
ayaldev
#4 Posted : Wednesday, September 15, 2021 8:28:25 PM(UTC)
ayaldev
Philippines
+1
davidcallahan
#5 Posted : Wednesday, September 29, 2021 6:33:06 PM(UTC)
davidcallahan
I already use a controller, but if you can't monitor what you're doing, it's not that helpful.
I need to SEE every lists
#6 Posted : Wednesday, September 29, 2021 7:10:52 PM(UTC)
Just my .2 cents
For easy switching between list views and be able to quickly select a item one can use the "ListShowHide" shortcut function (each specifying which list, might have to double hit it) . Works with unpinned frame also.
To have visual overview of all Lists at once i personally would revert to creating some external application that shows every list (with selected marked) in a windows form (list info pulled from the API XML). One could also pull that info into datasources and display in the open data source window ( just click between the various ones instead of having to scroll through a dropdown or have it as one of all combined with the ones selected being marked).
Until this FR is available
davidcallahan
#7 Posted : Wednesday, September 29, 2021 7:22:55 PM(UTC)
davidcallahan
Originally Posted by: doggy Go to Quoted Post
Just my .2 cents
Hey Doggy !
Hope you're well.
Thanks for the answer, the shortcut works well indeed, but in a hurry it's not that visual.
The API part could be great ! But the same problem would appear with datasources : I'd have to open 1 data source for every video
#8 Posted : Wednesday, September 29, 2021 7:29:36 PM(UTC)
No you don't , you get a list of all inputs in a List input (either split per list input or all in one big list depending on the xpath used)
#9 Posted : Wednesday, September 29, 2021 7:33:13 PM(UTC)
example for all:
XML
URL http://127.0.0.1:8088/api
xpath: //list/item
