darkhorse.home
#1 Posted : Monday, September 15, 2014 3:40:40 AM(UTC)
darkhorse.home
Hello!
Possible to make support for Google Glass in vMix?
For example in Livestream http://help.livestream.c...s-with-livestream-studio
hogwam
#2 Posted : Thursday, September 18, 2014 5:28:20 AM(UTC)
hogwam
using this https://github.com/fyhertz/libstreaming you can get an RTSP feed from any android device (inc glass), which you can then pull into vMix via a 'stream' input.
I'd imagine the app mentioned above harnesses this facility
