Thanks: 1 times Was thanked: 7 time(s) in 7 post(s)
using this https://github.com/fyhertz/libstreaming you can get an RTSP feed from any android device (inc glass), which you can then pull into vMix via a 'stream' input. I'd imagine the app mentioned above harnesses this facility
