Confusion about Settings>Output
Joined: 8/22/2021(UTC) Posts: 6  Location: NC Thanks: 1 times
On the Settings > Outputs/NDI/SRT tab there is a gear icon that lets you choose the resolution and bitrate of each output. I understand Output 1 is the "Record/Stream/External" output.
How do the resolution and bitrate settings here differ from the settings that can be chosen through the "Stream" or "Record" gear icons? If you choose one resolution under the Outputs/NDI/SRT tab, and a different resolution under the Stream gear icon, which setting is used?
Bump. I'm sure this is a simple answer but im not finding it anywhere.
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
 1 user thanked richardgatarski for this useful post.
