everything
#1 Posted : Sunday, August 22, 2021 12:39:14 AM(UTC)
everything
On the Settings > Outputs/NDI/SRT tab there is a gear icon that lets you choose the resolution and bitrate of each output. I understand Output 1 is the "Record/Stream/External" output.
How do the resolution and bitrate settings here differ from the settings that can be chosen through the "Stream" or "Record" gear icons? If you choose one resolution under the Outputs/NDI/SRT tab, and a different resolution under the Stream gear icon, which setting is used?
everything
#2 Posted : Wednesday, August 25, 2021 7:41:16 AM(UTC)
everything
Bump. I'm sure this is a simple answer but im not finding it anywhere.
richardgatarski
#3 Posted : Wednesday, August 25, 2021 4:26:22 PM(UTC)
richardgatarski
Was thanked: 297 time(s) in 250 post(s)
It's a little bit unclear in the Help. But, Settings/Output's quality selection is for SRT only.
https://www.vmix.com/help24/SRT.html
everything on 8/27/2021(UTC)
