i just wanted to change the software for my studio pc from obs to vmix. Using OBS my 4 channel SDI capture Card fromm Deltacast DELTA-3G-elp 40 works fine.
when i use vmix only the first added sdi input will be shown. all other 3 sdi inputs from the deltacast card are showing no pictures. I know that the deltacast DELTA-3G-elp 40 card is not on the supported hardware list but thats the card i have. buying a blackmagic card for example is to expensive for me right now.
is there a change i can get the deltacast card to use all 4 SDI inputs?
can anyone give a hint to solve the problem?
solved the problem. the support from deltacast send me a new driver. now all 4 SDI inputs are functional.
