calihc
#1 Posted : 4 years ago
calihc
Germany
i just wanted to change the software for my studio pc from obs to vmix.
Using OBS my 4 channel SDI capture Card fromm Deltacast DELTA-3G-elp 40 works fine.
when i use vmix only the first added sdi input will be shown. all other 3 sdi inputs from the deltacast card are showing no pictures.
I know that the deltacast DELTA-3G-elp 40 card is not on the supported hardware list but thats the card i have.
buying a blackmagic card for example is to expensive for me right now.
is there a change i can get the deltacast card to use all 4 SDI inputs?
calihc
#2 Posted : 4 years ago
calihc
Germany
can anyone give a hint to solve the problem?
calihc
#3 Posted : 4 years ago
calihc
Germany
solved the problem.
the support from deltacast send me a new driver.
now all 4 SDI inputs are functional.
Deni
#4 Posted : 7 months ago
Deni
Germany
wie hast du es geschafft, die Deltacast mit OBS zu betreiben?
War es ein PC oder ein Mac?
Funktioniert es mit der aktuellen Version auch noch?
Ich probiere es gerade mit einem Mac und schaffe es nicht, dass OBS die Delta Karte erkennt.
Viele Grüße!
