youngBu
#1 Posted : Wednesday, August 11, 2021 12:20:05 PM(UTC)
youngBu
Korea, Republic Of
I am having a problem when adding xml url in Data source.
The xml url includes web api auth key in Query String parameter. So I tested it and found it working on chrome browser.
But when adding xml url to Data source, it returned error code.
I think the problem is auth key including (+) character. Maybe its not decoded properly and translated to be understood by vMix.
Thanks.
The solution I found is to make use of google sheet.
- how to use google sheet
https://www.vmix.com/kno...s-with-vmix-data-sources
- how to import xml data with xpath expression in google sheet
https://zapier.com/blog/...-sheets-importxml-guide/
I think the problem happens when appropriate library for web url is not used.
Related thread is
https://stackoverflow.co...-encoding-using-c-sharp1
