Prevent encoded url to decoded url?
Hi, I am having a problem when adding xml url in Data source. The xml url includes web api auth key in Query String parameter. So I tested it and found it working on chrome browser. But when adding xml url to Data source, it returned error code. I think the problem is auth key including (+) character. Maybe its not decoded properly and translated to be understood by vMix. Thanks.
The solution I found is to make use of google sheet. - how to use google sheet https://www.vmix.com/kno...s-with-vmix-data-sources- how to import xml data with xpath expression in google sheet https://zapier.com/blog/...-sheets-importxml-guide/
I think the problem happens when appropriate library for web url is not used. Related thread is https://stackoverflow.co...-encoding-using-c-sharp1
