fenki86
#1 Posted : Tuesday, August 10, 2021 2:27:07 AM(UTC)
fenki86
Hy everyone!
I just got my Xtouch-Compact and the Shortcuts work flawlessly. However I'm stuck with the activators. I tried to use the motorized faders however they always change themself back to the lowest position instead of the Input-Volume. I've tried to find the key with touching it, with moving it, without touching it - all with no result. Anyone has an idea where I make the mistake?
Thanks for your help
_________________________
for anyone with the same problem - I just solved it. Download the Behringer X-Touch Editor and set the Device to Standard-Mode instead of MC. That way it'll work.
