	Hardware Compatibility
	[SOLVED] Behringer Xtouch-Compact Activators
 Thanks: 22 timesWas thanked: 10 time(s) in 10 post(s)
                Hy everyone!
 I just got my Xtouch-Compact and the Shortcuts work flawlessly. However I'm stuck with the activators. I tried to use the motorized faders however they always change themself back to the lowest position instead of the Input-Volume. I've tried to find the key with touching it, with moving it, without touching it - all with no result. Anyone has an idea where I make the mistake?
 Thanks for your help
 _________________________
 for anyone with the same problem - I just solved it. Download the Behringer X-Touch Editor and set the Device to Standard-Mode instead of MC. That way it'll work.
