imesi
#1 Posted : Thursday, September 11, 2014 9:27:27 AM(UTC)
imesi
Guys, I'm editing an existing title Vmix, I'm wanting to put a watch. But I can not. Does anyone know what I'm doing wrong?[URL=http://www.casimages.com.br/i/140910032716737509.png.html]UserPostedImage
hogwam
#2 Posted : Friday, September 12, 2014 8:38:59 AM(UTC)
hogwam
http://www.vmix.com.au/k...te-and-time-into-a-title
try a space after the '0'
{0: hh:mm}
if you want 24hr format
{0: HH:mm}
imesi
#3 Posted : Friday, September 12, 2014 9:25:34 AM(UTC)
imesi
hogwam wrote:
http://www.vmix.com.au/knowledgebase/article.aspx/25/how-do-i-insert-the-current-date-and-time-into-a-title
{0: hh:mm}
{0: HH:mm}
Now I found out what it was. In the existing title Vmix "Ticker HD" does not work in other securities normally works. Hogwam Thanks for the help.
fenki86
#4 Posted : Monday, September 15, 2014 4:38:53 PM(UTC)
fenki86
If you'd like to add the clock to the ticker you should probably consider the Multiview Option... just double click the Lower Third with the Ticker and under the Tab Multiview you can add a second Input that includes the Clock...
now you should be able to overlay the ticker including the clock...
greetz
fenki
Thremir
#5 Posted : Monday, September 15, 2014 7:16:12 PM(UTC)
Thremir
{0: hh:mm}
{0: HH:mm}
Could it be possible that the textbox is not a "TextBlock" and not a "TextBlockDesign"? (within the XAML file, of course).
I haven't tested it out due to not being able to use my workstation at the moment, but I thought I've seen this problem before.
Also note that if you're using an editor you'll need to add the "vMix title Library.dll" as a reference.
Cheers,
Håvard
Njastad Webshop
