Create a watch on existing title
Joined: 8/13/2014(UTC) Posts: 9  Location: Poços de Caldas - BRASIL Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Guys, I'm editing an existing title Vmix, I'm wanting to put a watch. But I can not. Does anyone know what I'm doing wrong?[URL=http://www.casimages.com.br/i/140910032716737509.png.html]
Thanks: 1 times Was thanked: 7 time(s) in 7 post(s)
hogwam wrote:http://www.vmix.com.au/knowledgebase/article.aspx/25/how-do-i-insert-the-current-date-and-time-into-a-title
try a space after the '0'
{0: hh:mm}
if you want 24hr format {0: HH:mm} Now I found out what it was. In the existing title Vmix "Ticker HD" does not work in other securities normally works. Hogwam Thanks for the help.
Thanks: 22 times Was thanked: 10 time(s) in 10 post(s)
If you'd like to add the clock to the ticker you should probably consider the Multiview Option... just double click the Lower Third with the Ticker and under the Tab Multiview you can add a second Input that includes the Clock...
now you should be able to overlay the ticker including the clock...
greetz
fenki
You have been a member since:: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
imesi wrote:hogwam wrote:http://www.vmix.com.au/knowledgebase/article.aspx/25/how-do-i-insert-the-current-date-and-time-into-a-title
{0: hh:mm}
if you want 24hr format {0: HH:mm} Now I found out what it was. In the existing title Vmix "Ticker HD" does not work in other securities normally works. Hogwam Thanks for the help. Could it be possible that the textbox is not a "TextBlock" and not a "TextBlockDesign"? (within the XAML file, of course). I haven't tested it out due to not being able to use my workstation at the moment, but I thought I've seen this problem before. Also note that if you're using an editor you'll need to add the "vMix title Library.dll" as a reference. Cheers, Håvard Njastad Webshop
