NDI
NDI Feed and Output stuttering
Hello, I am currently facing an issue when I send NDI feed out to another PC to stream out the feed with a delay(OBS). Trying to do this to reduce the load on my current PC. The set up is like this  New Project (1).png (8kb) downloaded 10 time(s).PC 1(Cleanfeed) PC 2(Replay) PC 3(Stream) PC 4(Delay) PC 1 sends cleanfeed to PC 2 and PC 3 via NDI PC 2 sends replay feed via NDI to PC 3 PC 3 uses these feed and adds on overlays/videos/vmix calls(4 calls) and sends out the feed via NDI to PC 4 for delay to sites. The issue I am facing is when I send out NDI from PC 3 to PC 4, all NDI feeds in and out of PC 3 start to stutter. All other PCs are fine. The feed received by PC 4 from PC 3 will also stutter. However, when I remove PC 4 entirely from the equation by having PC 3 NDI to OBS on the same PC, the NDI feeds are fine. What I noticed on PC 3 when troubleshooting was that when the feeds from PC 1 and 2 are smooth, the NDI from 3 to 4 froze. When I refreshed it on PC 4, the NDI feeds in from 1 and 2 and out to PC 4 will also stutter. Massive frame drops from both source and renderer. PC 2 receiving 1 NDI in and sending 1 NDI out faces no issues. PC 3's specs are i9-9900k 64gb ram 2667mhz zotec 1070ti asrock b360 pro4 All lan connections are 1gbps. Anyone has any idea why this might be happening?
NDI
