Feature Requests
API access to Input Rotate X, Y, Z
Greetings all.
I'd really like to get access to the Input Rotate X Y Z parameters via the TCP API. So far the API offers Zoom, PanX & PanY. I have a few projects that I am working on that require is to dynamically adjust the rotate also.
It would open up some great GFX abilities to be able to rotate things like needles in speedo gauges and suchlike. vMix is truly a versatile production powerhouse and this would augment it's abilities.
Thanks,
Matt
+1 for this feature. That would be a really handy addition. This would take the graphics package of Vmix to a much more functional level to make some really cool graphics.
That would be bloody handy. +1 for this
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Exactly what I need as well.
+1
Joined: 9/20/2015(UTC) Posts: 44   Location: Hyderabad Thanks: 88 times Was thanked: 22 time(s) in 12 post(s)
Not sure if bumping is a done thing here... But I really hoped this would be included in 25. So far not. Please Martin :D
Rank:: Advanced Member
Joined: 11/23/2020(UTC) Posts: 243  Location: Wichita Thanks: 11 times Was thanked: 32 time(s) in 28 post(s)
Please Martin! Still desperately need this! Having to resort to a library of images with the gauge needle in all the possible positions and swapping the image via API. VMIX seems to hate doing that. Simple rotate via API would be so good!
Joined: 2/26/2014(UTC) Posts: 83  Location: Canada Thanks: 18 times Was thanked: 16 time(s) in 16 post(s)
Joined: 2/8/2023(UTC) Posts: 24  Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
+1 Sometimes you have to reframe the camera in vmix itself and then it can happen that black edges remain. You could make a script that warns that the framing has been done inaccurately, but since the scripts do not have information about the input rotate state, such a script unfortunately does not work :/
Joined: 11/14/2012(UTC) Posts: 366  Location: Finland Thanks: 235 times Was thanked: 25 time(s) in 23 post(s)
Feature Requests
