nowski
#1 Posted : Thursday, July 22, 2021 9:46:04 PM(UTC)
nowski
Hi there, I'm coming back to my VMIX cloud AMI for Amazon, which up to now, only been using RDP to connect to.
I am told this is a bad idea, but the alternatives mentioned have been Terdici and Team Viewer, both of these are a hefty monthly sub, which I dont really want to swallow as currently not using all that often. What other options do you suggest? my client may well be a mac
tcconway
#2 Posted : Friday, July 23, 2021 12:23:11 AM(UTC)
tcconway
You could look at Parsec, but I really really recommend Teradici. It's only $0.50/hour and is tied to the AMI usage. For what it delivers is money well spent.
nowski
#3 Posted : Friday, July 23, 2021 7:18:05 PM(UTC)
nowski
Thanks, I didnt know you could rent it like that. I guess you need to build on a Teradici Marketplace AMI though- darn. I already invested a bunch of time building the Vmix instance. Is it possible to bolt it on after the fact?
