Remote viewer for VMIX Cloud not requiring a subscription
Thanks: 15 times Was thanked: 11 time(s) in 9 post(s)
Hi there, I'm coming back to my VMIX cloud AMI for Amazon, which up to now, only been using RDP to connect to. I am told this is a bad idea, but the alternatives mentioned have been Terdici and Team Viewer, both of these are a hefty monthly sub, which I dont really want to swallow as currently not using all that often. What other options do you suggest? my client may well be a mac
Joined: 3/26/2020(UTC) Posts: 23   Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
You could look at Parsec, but I really really recommend Teradici. It's only $0.50/hour and is tied to the AMI usage. For what it delivers is money well spent.
Thanks, I didnt know you could rent it like that. I guess you need to build on a Teradici Marketplace AMI though- darn. I already invested a bunch of time building the Vmix instance. Is it possible to bolt it on after the fact?
