Bug or Feature? CC always active on start
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Running vMix Pro 24.0.63 (and previous versions same behaviour): After loading a preset, the Color Correction for an input is turned ON, even when the preset is saved with CC turned OFF for that particular input. Even, when you have to restart vMix (eg. after changing an Audio Output), CC is turned ON by default.
It had irritated me before, but now I have tested it. :) Is that by design? Are people used to it that way?
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Yes, by design. That button is for previewing changes only. If you want to turn off colour correction, select the Reset preset.
