dmwkr
#1 Posted : Wednesday, July 7, 2021 3:47:40 AM(UTC)
dmwkr
Running vMix Pro 24.0.63 (and previous versions same behaviour):
After loading a preset, the Color Correction for an input is turned ON, even when the preset is saved with CC turned OFF for that particular input. Even, when you have to restart vMix (eg. after changing an Audio Output), CC is turned ON by default.
It had irritated me before, but now I have tested it. :) Is that by design? Are people used to it that way?
#2 Posted : Thursday, July 8, 2021 3:07:45 PM(UTC)
Yes, by design. That button is for previewing changes only.
If you want to turn off colour correction, select the Reset preset.
dmwkr on 7/8/2021(UTC)
dmwkr
#3 Posted : Thursday, July 8, 2021 6:47:07 PM(UTC)
dmwkr
Thank you, Martin!
Guest (4)
