smudge1977
#1 Posted : Saturday, September 6, 2014 4:01:07 PM(UTC)
smudge1977
Was thanked: 4 time(s) in 1 post(s)
I know you can use the set text short cut to add / subtract from a numeric value by putting
+=1 or -=1 in the text box
What other clever options etc. are there
Also with the control of timers and there start and stop points / current value.
i.e. i would be useful to be able to adjust a timer if vMix becomes out of step with 'match' time
any input greatly received
K
curtismacd31
#2 Posted : Sunday, September 7, 2014 1:33:39 PM(UTC)
curtismacd31
Hey, I am working on a ui that will allow all that stuff to be controlled and can run on the local machine or on a seperate machine running onthe same network . Currently for my use I have it controlling team names, score and clock. let me know if you'd be interested in something like that. I can tailor it to what you need.
smudge1977
#3 Posted : Sunday, September 7, 2014 2:47:07 PM(UTC)
smudge1977
Hi sounds interesting....
I have also been pointed to this:
http://forums.vmix.com.a...ts&m=11275#post11275
Is this similar to your system....??
Keith
Timers are the main thing i think - i would like to learn also how to animate titles but this will come.
The other way this can be done is via flash!
I would like to keep things simple for the user so it can all be controlled from a single web ui though as this also means any pad and control scoreboards remotely
I guess I am trying to take a video mixing application and make it in to a cross spot scoreboard application! This they gives the options of video stings etc when goals are scored and things.
Cricket is a fairly complex stop and it seems Hockey can have lots of different penalty timers all running
K
fenki86
#4 Posted : Monday, September 8, 2014 8:38:22 AM(UTC)
fenki86
I'd be interested in that. Currently I'm using simple shortcuts via settext and start/pausecountdown and trigger them on a tablet via the web-interface... however especially with penalty times it get's very tricky... are you planning to implement a penalty clock in your interface as well?
