Thanks: 19 times Was thanked: 4 time(s) in 1 post(s)
I know you can use the set text short cut to add / subtract from a numeric value by putting +=1 or -=1 in the text box
What other clever options etc. are there Also with the control of timers and there start and stop points / current value. i.e. i would be useful to be able to adjust a timer if vMix becomes out of step with 'match' time
any input greatly received
K
Hey, I am working on a ui that will allow all that stuff to be controlled and can run on the local machine or on a seperate machine running onthe same network . Currently for my use I have it controlling team names, score and clock. let me know if you'd be interested in something like that. I can tailor it to what you need.
Hi sounds interesting.... I have also been pointed to this: http://forums.vmix.com.a...ts&m=11275#post11275Is this similar to your system....?? Keith Timers are the main thing i think - i would like to learn also how to animate titles but this will come. The other way this can be done is via flash! I would like to keep things simple for the user so it can all be controlled from a single web ui though as this also means any pad and control scoreboards remotely I guess I am trying to take a video mixing application and make it in to a cross spot scoreboard application! This they gives the options of video stings etc when goals are scored and things. Cricket is a fairly complex stop and it seems Hockey can have lots of different penalty timers all running K
Thanks: 22 times Was thanked: 10 time(s) in 10 post(s)
curtismacd31 wrote:Hey, I am working on a ui that will allow all that stuff to be controlled and can run on the local machine or on a seperate machine running onthe same network . Currently for my use I have it controlling team names, score and clock. let me know if you'd be interested in something like that. I can tailor it to what you need. I'd be interested in that. Currently I'm using simple shortcuts via settext and start/pausecountdown and trigger them on a tablet via the web-interface... however especially with penalty times it get's very tricky... are you planning to implement a penalty clock in your interface as well?
