GT
TCP command line to change text
Joined: 11/22/2018(UTC) Posts: 94  Location: Worthing Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
I am looking for a way to update a textline using TCP. I would like to use companion to send a TCP command to change text in a textline in a GT Designer Title. Can anyoone post me an example to start with?
Kind regards, Frank
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
You can use the built-in vMix commands in Companion to update a title. Add an 'Title - Adjust title text' action to a button and then enter your new text as the Value. The 'Layer' field selects the (zero-based) index of the line of text to update. At least, it works for me - I don't know if all GT titles respond the same way.
GT
