FrankLeggett
#1 Posted : Wednesday, June 23, 2021 6:23:22 PM(UTC)
FrankLeggett
I am looking for a way to update a textline using TCP. I would like to use companion to send a TCP command to change text in a textline in a GT Designer Title. Can anyoone post me an example to start with?
Kind regards,
Frank
matkeane
#2 Posted : Wednesday, June 23, 2021 7:57:24 PM(UTC)
matkeane
Was thanked: 21 time(s) in 21 post(s)
You can use the built-in vMix commands in Companion to update a title. Add an 'Title - Adjust title text' action to a button and then enter your new text as the Value. The 'Layer' field selects the (zero-based) index of the line of text to update. At least, it works for me - I don't know if all GT titles respond the same way.
