Is Vmix compatible with Rosetta 2 for new mini Mac's M1
Joined: 5/16/2021(UTC) Posts: 2  Location: Saint Michael
So I plan on upgrading my computer this summer. Right now I have a Mac Book Pro and am using bootcamp so I'm able to use Vmix. I plan on purchasing the new mini Mac M1's and have found out that bootcamp is not available this computer. They do have something similar called Rosetta 2 which still allows the Mac to run Window's apps. With that said was wondering if anyone knows if the Vmix software can work after installing the rosetta 2 software on the mac's with the M1 chip. TIA
You have been a member since:: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
I've seen several posts with people running it succesfully. But you will basically run with a huge waste of resources, so don't expect good performance.
As far as VMix being compatible, I doubt the VMix team has tested it extensively, if at all, so I wouldn't run it on a critical show or without a backup.
Thanks for your input Vince, yeah sounds like I should stay away from the M1's if I want to run Vmix!!
