RichardStPaul
#1 Posted : Friday, June 18, 2021 2:37:10 AM(UTC)
RichardStPaul
I'm trying to add a Bosch Flexidome 4000i Input. I can do it in OBS (get him off the forum I hear you screaming) by adding Media Source and the url RTSP://username:password@IPaddress:554.
If I try the same url in vMix with both RTSP over UDP or TCP stream types I get the error:
Invalid URL. A port was expected because of there is a colon (:) present but the port cound not be parsed.
If I try the same url in VLC input it appears to work but the input is just a black screen that is 32x32 not 1080p.
I've installed the stand alone VLC software. It requires the URL without the username and password and uses a dialogue box for them.
Thanks for your help
Richard
