Can't add Bosch Flexidome 4000i Input
Joined: 6/1/2021(UTC) Posts: 3  Location: Stockton Thanks: 1 times
I'm trying to add a Bosch Flexidome 4000i Input. I can do it in OBS (get him off the forum I hear you screaming) by adding Media Source and the url RTSP://username:password@IPaddress:554.
If I try the same url in vMix with both RTSP over UDP or TCP stream types I get the error: Invalid URL. A port was expected because of there is a colon (:) present but the port cound not be parsed.
If I try the same url in VLC input it appears to work but the input is just a black screen that is 32x32 not 1080p.
I've installed the stand alone VLC software. It requires the URL without the username and password and uses a dialogue box for them.
Thanks for your help Richard
