	Feature Requests
	Playlist and Trigger transitions
 Joined: 8/19/2020(UTC) Posts: 4 Was thanked: 1 time(s) in 1 post(s)
                Playlist items run to end and stop before transitions start. Videos pausing to a still image before fade starts is not preferred behaviour. Transitions should start early enough for a video to play smoothly to the cut-off point.
 OnCompletion trigger lets a video run out to a still image before starting a transition to another input. Transitions should start early enough for a video to play smoothly to the cut-off point.
 OnTransitionIn trigger does not fire off a transition function. This would make possible to show a short B-roll clip with a triggered title and then return back to another input using the delay feature.
	Feature Requests
