Feature Requests
Playlist and Trigger transitions
Joined:: 8/19/2020(UTC) Posts: 4  Was thanked: 1 time(s) in 1 post(s)
Playlist items run to end and stop before transitions start. Videos pausing to a still image before fade starts is not preferred behaviour. Transitions should start early enough for a video to play smoothly to the cut-off point.
OnCompletion trigger lets a video run out to a still image before starting a transition to another input. Transitions should start early enough for a video to play smoothly to the cut-off point.
OnTransitionIn trigger does not fire off a transition function. This would make possible to show a short B-roll clip with a triggered title and then return back to another input using the delay feature.
Feature Requests
