monster
#1 Posted : 4 years ago
monster
Poland
I'm trying to configure vMix Call with "Allow only direct peer to peer connections".
I've already read these pages:
https://www.vmix.com/kno...l-direct-connection-mode
and
https://www.vmix.com/kno...on-issues-with-vmix-call
I have Mikrotik firewall on which I added rules:
/ip firewall filter print
chain=input action=accept protocol=udp in-interface=ether1 dst-port=49152-65535 log=no log-prefix=""
Unfortunetely caller cant connect to vMix.
In vMix Call Manager I see:
XXXXXXX 02:50:26 PM
Ready to accept caller at https://www.vmixcall.com/ with Password XXXXXXX
XXXXXXX 02:50:26 PM
Callers can also use the following link: https://vmix.at/yyyyyyyyyyy
Pawel 02:50:45 PM
logged in
Pawel 02:50:46 PM
Caller has made initial contact!
Pawel 02:50:46 PM
Sending our reply to initiate the call...
When I untick "Allow only direct peer to peer connections" I can connect without any problems,
but I suppose that with p2p connection I will achieve lower latency and better image quality.
Should I add any DNAT rule?
Any other filter rules?
Thanks in advance.
Chris Daum
#2 Posted : 4 years ago
Chris Daum
Germany
if the caller can´t connect while "allow only p2p..." is selected
that is an issue of the network/firewall configuration of the calling side.
In a couple (if not a lot or most) of company networks and company administrated
computers it is not possible to connect p2p.
And then if you only allow p2p, no connection will set up.
If a connection via p2p is possible you will avoid connecting
via an external server, which can sometimes be very busy with in/out traffic.
Due to this the video quality esspecially resolution can be lowered with expanding traffic on the server.
I am not a network administrator or firewall expert so consider this as the most basic and simple explanation!
monster
#3 Posted : 4 years ago
monster
Poland
Caller is connected directly to Internet.
Android Smartphone with LTE Internet.
