Hallaman
#1 Posted : Monday, June 7, 2021 10:58:48 PM(UTC)
Hallaman
Hi All,
I have the X-Touch One. I can map all of the functions I want to control using Midi and Activators except the Motorized Fader.
Is it possible to set the fader via a script? I can set it easily via activator for audio levels etc, but there is no activator for the Replay Speed.
So, I can set the speed with the fader, but the fader can't be set via Activator directly. I'm hoping I could use a script to gather the current speed setting and then pass that to the fader.
Thoughts?
Input?
Code?
All are welcome,
Cheers,
JB
Hallaman
#2 Posted : Thursday, June 10, 2021 12:16:46 AM(UTC)
Hallaman
For those playing along at home, I found a way around my little problem. (For Now - Until replay speed becomes a selection in activators)
I just wrote a script that takes the speed of the replay and applies it to a dummy audio inputs volume. I then use this inputs volume as an activator to my motorized fader.
This is the code. The name of the dummy input is RSDUMMY
dim speed As Double
dim faderVolume As Integer
do while true
dim xml as string = API.XML()
x.loadxml(xml)
speed = (x.SelectSingleNode("//replay/@speed").Value)
speed = speed * 100
Console.WriteLine(speed)
faderVolume = cint(speed)
API.Function("SetVolume",Input:="RSDUMMY",Value:= faderVolume.tostring())
sleep(200)
loop
Cheers,
JB
thanks 1 user thanked Hallaman for this useful post.
Chuck8 on 6/22/2021(UTC)
#3 Posted : Thursday, June 10, 2021 1:21:51 AM(UTC)
consider using for value +=stepnumber -=stepnumber to increase/decrease from current values
There is also a replaysetspeed function
Chuck8
#4 Posted : Tuesday, June 22, 2021 3:56:16 AM(UTC)
Chuck8
Thanks for the fix! Came looking for this exact question, so will be purchasing the X-Touch One now.
