Instant Replay
Replay Speed - Motorized Fader
Hi All,
I have the X-Touch One. I can map all of the functions I want to control using Midi and Activators except the Motorized Fader. Is it possible to set the fader via a script? I can set it easily via activator for audio levels etc, but there is no activator for the Replay Speed. So, I can set the speed with the fader, but the fader can't be set via Activator directly. I'm hoping I could use a script to gather the current speed setting and then pass that to the fader.
Thoughts? Input? Code?
All are welcome,
Cheers, JB
For those playing along at home, I found a way around my little problem. (For Now - Until replay speed becomes a selection in activators) I just wrote a script that takes the speed of the replay and applies it to a dummy audio inputs volume. I then use this inputs volume as an activator to my motorized fader. This is the code. The name of the dummy input is RSDUMMY Quote: dim speed As Double dim faderVolume As Integer
do while true
dim xml as string = API.XML() dim x as new system.xml.xmldocument x.loadxml(xml)
speed = (x.SelectSingleNode("//replay/@speed").Value)
speed = speed * 100
Console.WriteLine(speed)
faderVolume = cint(speed)
API.Function("SetVolume",Input:="RSDUMMY",Value:= faderVolume.tostring())
sleep(200) loop
Cheers, JB
 1 user thanked Hallaman for this useful post.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
consider using for value +=stepnumber -=stepnumber to increase/decrease from current values
There is also a replaysetspeed function
Thanks for the fix! Came looking for this exact question, so will be purchasing the X-Touch One now.
Instant Replay
