Global Triggers. Is it possible.
Joined: 5/9/2021(UTC) Posts: 17  Location: Thessaloniki Thanks: 2 times
Is it possible to run a script every time any input is push into program?
I know I can do that for every input, but is it possible to define global triggers?
Why not the opposite and let a script constantly poll for a change ?
Originally Posted by: doggy  Why not the opposite and let a script constantly poll for a change ? This is indeed a solution. Just a CPU intensive one.
Originally Posted by: buffos  This is indeed a solution. Just a CPU intensive one.
Very @@ and calling one isn't ?
Originally Posted by: doggy  Originally Posted by: buffos  This is indeed a solution. Just a CPU intensive one.
Very @@ and calling one isn't ? If I understand correctly, you say have a script in a never-ending loop that checks if the program has changed and does what it needs to do. This is definitely much more CPU intensive than an event-driven solution which runs what it needs to run only when an event occurs. (I guess this is what triggers do) In an event-driven implementation, you have a single loop for the events that spawn registered callbacks.
Frankly i don't care. Question was if it was possible and indeed there is a solution How much CPU % will it add for the practical convenience ?
Frankly i don't care. Question was if it was possible and indeed there is a solution How much CPU % will it add for the practical convenience ? Sorry, the question was if there are global triggers. A solution that will make the CPU jump to 100% (of the thread since I guess the execution is per thread) Anyway. Thank you for your help.
Originally Posted by: buffos  A solution that will make the CPU jump to 100% (of the thread since I guess the execution is per thread)
