buffos
#1 Posted : Thursday, May 27, 2021 4:41:57 AM(UTC)
buffos
Greece
Is it possible to run a script every time any input is push into program?
I know I can do that for every input, but is it possible to define global triggers?
#2 Posted : Thursday, May 27, 2021 5:44:15 AM(UTC)
Why not the opposite and let a script constantly poll for a change ?
buffos
#3 Posted : Thursday, May 27, 2021 6:18:48 AM(UTC)
buffos
Greece
This is indeed a solution. Just a CPU intensive one.
#4 Posted : Thursday, May 27, 2021 7:39:10 AM(UTC)
Very @@
and calling one isn't ?
buffos
#5 Posted : Thursday, May 27, 2021 8:04:41 AM(UTC)
buffos
Greece
Very @@
If I understand correctly, you say have a script in a never-ending loop that checks if the program has changed and does what it needs to do.
This is definitely much more CPU intensive than an event-driven solution which runs what it needs to run only when an event occurs. (I guess this is what triggers do)
In an event-driven implementation, you have a single loop for the events that spawn registered callbacks.
#6 Posted : Thursday, May 27, 2021 8:14:53 AM(UTC)
Frankly i don't care. Question was if it was possible and indeed there is a solution
How much CPU % will it add for the practical convenience ?
buffos
#7 Posted : Thursday, May 27, 2021 8:20:39 AM(UTC)
buffos
Greece
Sorry, the question was if there are global triggers.
A solution that will make the CPU jump to 100% (of the thread since I guess the execution is per thread)
Anyway. Thank you for your help.
#8 Posted : Thursday, May 27, 2021 8:37:51 AM(UTC)
