	NDI
	NDI Targeted Output to BirdDog Studio NDI or Mini
 Joined: 5/21/2021(UTC) Posts: 1  Location: Los Angeles |
                I'm considering purchasing the vMix software as a back up to my tri-caster mini 4K.I'm writing to ask if the targeted, NDI output capabilities of the mini 4K are available in the V-Mix software.
 The tri-caster allows me to output four separate NDI signals to targeted NDI devices. My question is, if I have two or three BirdDog NDI converter's on the same network as the vMix computer, can I send or target seperate NDI outputs such as one NDI program mix to one BirdDog device which is then plugged into an HDMI monitor and then send a separate NDI signal to a second BirdDog converter which is attached to a different monitor.
 The application for this would be in a live event where the program would go to the projectors via NDI while a second NDI output would go to a front of house monitor with a countdown clock for the speakers.
 I believe the Wirecast has a feature called "NDI output" that will output a single mix into the network, but I do not know that it will allow me to actually target an NDI/HDMI converter.
 If V-Mix does have targeted NDI output capability, how many separate NDI outputs can it put out?
 I do hope this makes sense, thank you in advance.
 Chris
	NDI
