narcus
#1 Posted : Tuesday, May 18, 2021 12:42:55 AM(UTC)
narcus
Austria
Is there a way to trigger an event in companion when vmix has finished playing a clip? I want to mute the input of my Behringer X32 after the clip has finished playing in vmix.
cheers Marcus
narcus
#2 Posted : Wednesday, May 19, 2021 3:48:56 PM(UTC)
narcus
Austria
so this is my answer to my question :-)
Dim webStream As Stream
Dim webResponse = ""
Dim req As HttpWebRequest
Dim res As HttpWebResponse
req = CType(WebRequest.Create("http://127.0.0.1:8000/press/bank/98/25"), HttpWebRequest)
res = CType(req.GetResponse(), HttpWebResponse)
webStream = res.GetResponseStream() ' Get Response
Dim webStreamReader As New StreamReader(webStream)
While webStreamReader.Peek >= 0
webResponse = webStreamReader.ReadToEnd()
End While
thanks 2 users thanked narcus for this useful post.
stevespaw on 5/19/2021(UTC), RTE on 2/14/2022(UTC)
JamesDunn
#3 Posted : Thursday, August 5, 2021 5:34:56 AM(UTC)
JamesDunn
Excuse my ignorance but where do I put this code? Thanks.
narcus
#4 Posted : Thursday, August 19, 2021 10:13:45 PM(UTC)
narcus
Austria
Triggers script.png (106kb) downloaded 3 time(s).
#5 Posted : Thursday, August 19, 2021 10:16:36 PM(UTC)
@ Narcus
You put scripting code in the trigger settings ? ;-)
narcus
#6 Posted : Thursday, August 19, 2021 10:27:30 PM(UTC)
narcus
Austria
first I create a script in Settings/scripting then I trigger the script in triggers
