Trigger event for Companion in vmix
Joined: 10/20/2017(UTC) Posts: 23  Thanks: 5 times Was thanked: 2 time(s) in 1 post(s)
Is there a way to trigger an event in companion when vmix has finished playing a clip? I want to mute the input of my Behringer X32 after the clip has finished playing in vmix.
cheers Marcus
so this is my answer to my question :-)
Dim webStream As Stream Dim webResponse = "" Dim req As HttpWebRequest Dim res As HttpWebResponse req = CType(WebRequest.Create("http://127.0.0.1:8000/press/bank/98/25"), HttpWebRequest) res = CType(req.GetResponse(), HttpWebResponse) webStream = res.GetResponseStream() ' Get Response Dim webStreamReader As New StreamReader(webStream) While webStreamReader.Peek >= 0 webResponse = webStreamReader.ReadToEnd() End While
 2 users thanked narcus for this useful post.
Excuse my ignorance but where do I put this code? Thanks.
 Triggers script.png (106kb) downloaded 3 time(s).
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
@ Narcus
You put scripting code in the trigger settings ? ;-)
first I create a script in Settings/scripting then I trigger the script in triggers
