Joined: 2/28/2021(UTC) Posts: 9 Location: São Paulo Thanks: 2 times Was thanked: 2 time(s) in 1 post(s)
Hi guys I need a solution i will do an event and the Guest will enter by the vmix call and and inned to put a translator at same time. How can i biuld this? The Translator could be on same place as I or he could be remote in anothe vmix call. My question is how can I build this scenario? Because the guest shouldn´t listen the translator. Only the audience should listen the mix by the guest and the translator. Any ideas ??
Originally Posted by: kaduramos Hi guys I need a solution i will do an event and the Guest will enter by the vmix call and and pinned tutuapp to put a translator at same time. How can i biuld this? The Translator could be on same place as I or he could be remote in anothe vmix call. My question is how can I build this scenario? Because the guest shouldn´t vidmate listen the translator. Only the audience should listen the mix by the guest and the translator. Any ideas ?? Thanks Hi Kadu Ramos, even am trying similar stuff, can we talk in PM? Regards, Roel Hackett
Hi Roel Hackett Sure we can talk to try to solve this issue
