kaduramos
#1 Posted : Thursday, May 13, 2021 10:58:39 AM(UTC)
kaduramos
Brazil
Was thanked: 10 time(s) in 5 post(s)
Hi guys
I need a solution i will do an event and the Guest will enter by the vmix call and and inned to put a translator at same time. How can i biuld this?
The Translator could be on same place as I or he could be remote in anothe vmix call.
My question is how can I build this scenario?
Because the guest shouldn´t listen the translator. Only the audience should listen the mix by the guest and the translator.
Any ideas ??
darecem414
#2 Posted : Monday, May 17, 2021 5:57:22 PM(UTC)
darecem414
Originally Posted by: kaduramos Go to Quoted Post
Hi guys
I need a solution i will do an event and the Guest will enter by the vmix call and and pinned tutuapp to put a translator at same time. How can i biuld this?
Because the guest shouldn´t vidmate listen the translator. Only the audience should listen the mix by the guest and the translator.
Any ideas ??
Hi Kadu Ramos, even am trying similar stuff, can we talk in PM?
Roel Hackett
kaduramos
#3 Posted : Friday, May 21, 2021 2:12:43 PM(UTC)
kaduramos
Brazil
Hi Roel Hackett
Sure we can talk to try to solve this issue
