stevenallerton
#1 Posted : Wednesday, May 12, 2021 6:45:31 PM(UTC)
stevenallerton
Hi all
Just getting my head around all the features of vMix.
I am currently feeding a live video stream to a scoreboard via a submix for a clean feed, but I can't get action replay to show on that submix. It will show on output (to the internet stream) but not to the submix for the scoreboard.
Any ideas?
Cheers
#2 Posted : Wednesday, May 12, 2021 7:06:01 PM(UTC)
quick thought
layer the replay on the cleanfeed ( or a virtual of it )
set a trigger on the replay to turn on/off the layer on transition In/Out of the replay or similar
a Mix input might also be an option
stevenallerton on 5/12/2021(UTC)
stevenallerton
#3 Posted : Wednesday, May 12, 2021 8:25:30 PM(UTC)
stevenallerton
Originally Posted by: doggy Go to Quoted Post
quick thought
This was an excellent suggestion. I just set triggers for TransitionIn/Out and set the fade to mix 2 and it works well.
Thank you so much.
Cheers
