Instant Replay
Playout action replay to submix
Hi all
Just getting my head around all the features of vMix.
I am currently feeding a live video stream to a scoreboard via a submix for a clean feed, but I can't get action replay to show on that submix. It will show on output (to the internet stream) but not to the submix for the scoreboard.
Any ideas?
Cheers
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
quick thought
layer the replay on the cleanfeed ( or a virtual of it ) set a trigger on the replay to turn on/off the layer on transition In/Out of the replay or similar
a Mix input might also be an option
a Mix input might also be an option This was an excellent suggestion. I just set triggers for TransitionIn/Out and set the fade to mix 2 and it works well. Thank you so much. Cheers
Instant Replay
