jorgenscheel
#1 Posted : Wednesday, May 12, 2021 4:28:18 PM(UTC)
jorgenscheel
Views messages in topic : 4
Hi!
Would be very helpful if we can have AppendPreset in supported in the API. No GUI or selections, just blunt append the entire preset and all its contents.
An alternative is a flag in the preset itself that instructs vMix to append when opened (if you dont want to extend the API)
The ideal solution is support for all Inputs with the Addinput in API, but I assume there is a reason for the limited support for adding complex inputs with that method.
#2 Posted : Wednesday, May 12, 2021 6:52:48 PM(UTC)
if you have a open preset shortcut with leaving the value empty it will actually ask for which preset and allow you to append ( if that helps for now )
MartLeib
#3 Posted : Monday, June 7, 2021 3:04:16 PM(UTC)
MartLeib
Estonia
+1
